French translation
xaval
Post by xaval » May 22nd, ’19, 13:52
Thank you for this great application that I use everyday.
However there are some problems with the French translation where some characters are incorrect, for example:
ŕ instead of à
ű instead of û
č instead of è
ę instead of ê
etc.
Is it possible to contribute to the french translation to correct these errors?
Post by Tom » May 22nd, ’19, 15:55
Hi, thanks for reporting this. We will correct this in the next release.
French translation is about 90% completed and you are more than welcome to add the missing translations. Simply open French.Lang file from FastKeys/Resources/Languages folder and add the translations at the end of the file. Please send it to us and we will include it in the next release. Thanks! :D
