Clipboard command
orlando2bjr
Post by orlando2bjr » Aug 13th, ’18, 18:49
Hi, using this command:
clipboard = "" ; Start off empty to allow ClipWait to detect when the text has arrived.
Send ^c
ClipWait
characters := StrLen(clipboard)
Menu, Tray, Icon
TrayTip Caracteres, %characters% com espaços
I get this error:
---- #ErrorStdOut
622: i := VarSetCapacity(e,520) DllCall("GetModuleFileName",PTR,0,Str,e,UInt,260) VarSetCapacity(e,-1)
005: CoordMode,Mouse,Screen
006: SendMode,Input
007: SetTitleMatchMode,RegEx
012: Return (0.06)
628: Suspend,On
629: Suspend,Off
630: Return (216.42)
190: Clipboard = ""
191: Send,^c (0.01)
192: ClipWait
193: characters := StrLen(clipboard)
195: Menu,Tray,Icon (0.03)
196: TrayTip,Caracteres,%characters% com espaços
197: Return (3.53)
It also included Usage Statistics in the report, but since I've disabled it, it disappeared.
The shortcut is CTRL+SHIFT+ALT+WINDOWS+C.
Results are correct though.
orlando2bjr
Post by Tom » Aug 13th, ’18, 19:14
Running your script gives me no error. Can you post a printscreen?
orlando2bjr
Post by orlando2bjr » Aug 13th, ’18, 19:41
Sure, here it is:
It seems to happen on other functions as well, such as text expander. I've never noticed that. I thought it was normal for the autohotkey icon to stay in the tray after a command.
orlando2bjr
Post by Marko » Aug 14th, ’18, 05:11
Tray icon? Do you use Type: Script?
orlando2bjr
Post by orlando2bjr » Aug 14th, ’18, 20:04
No, at least not that I know of. I just used that command that I got from AHK help.
The tray icon I was referring to was this:
I thought this was normal behavior, but now I think it keeps showing up because of this error.
orlando2bjr
Post by Marko » Aug 15th, ’18, 19:54
Sorry, I can’t reproduce this. Could you send me your settings files with a detailed description of steps to reproduce it?
orlando2bjr
Post by orlando2bjr » Aug 19th, ’18, 14:21
Here it is.
Steps to reproduce:
  1. Select text
  2. Press CTRL + SHIFT + WIN + ALT + C (I use an ergodox keyboard)
  3. Watch the notification with character count.
  4. Authotkey icon appears on traybar and never closes. Open it to show error.
orlando2bjr
Post by Marko » Aug 20th, ’18, 18:48
Thanks. This is not an error but the result of showing the system tray icon in your script.
I suggest you using ToolTip, MsgBox instead of TrayTip.
orlando2bjr
Post by orlando2bjr » Aug 23rd, ’18, 19:46
It's much better with tooltip. I skipped the msgbox to avoid having to click to dismiss.
clipboard = ; Start off empty to allow ClipWait to detect when the text has arrived.
Send ^c
ClipWait
; Menu, Tray, Icon
; TrayTip Caracteres, %characters% com espaços
ToolTip %characters% com espaços
SetTimer, RemoveToolTip, -2000
RemoveToolTip:
ToolTip
Thanks a lot.
orlando2bjr
