Req: Option to truly disable quick-search and clipboard manager
orlando2bjr
Post by orlando2bjr » Jul 10th, ’18, 14:46
Can you add an option to truly disable these functions? Now, the only workaround is assigning a random shortcut to it (or am I missing anything?).
Besides avoiding conflicting shorcuts, maybe this could free some resources??
Thanks
orlando2bjr
Post by Marko » Jul 10th, ’18, 15:05
You can disable the functions by removing the shortcut (set it to None) - just locate the shortcut field and press Delete.
