dennisl
Post
by dennisl » Dec 8th, ’17, 09:49
I was curious why this "Auto Complete" feature was popping up for me (after updating to 4.04) as I have the Auto Complete module deactivated. By turning on/off a few of the features in preferences, it seemed to be that "Auto learn" was checked on, so I unchecked it and hit apply, and I haven't seen this occurrence again.
Just thought I would see if this was working as intended, given that this was part of the Auto Complete module and I had deactivated it.
Many thanks for the updates Marko!
dennisl on Dec 9th, ’17, 18:51, edited 3 times in total.
dennisl
Post
by dennisl » Dec 9th, ’17, 18:47
I needed to go back to an earlier image of my operating system, not because of FastKeys of course, but I just checked my previous settings from version 4.03 and Auto Learning was checked on along with having Auto Complete module off.
So this might not be the reason I was seeing an auto-complete word box appearing when typing partial words. For whatever reason, it seemed to stop when I unchecked Auto learn off in 4.04. It's just something I didn't have pop up (auto complete for partial words) when using 4.03.
I'll report if I find any specific behavior when upgrading to 4.04 again.
Post
by Marko » Dec 9th, ’17, 18:54
What you describe in your original post is a bug and will be resolved asap.
Thanks for reporting.
dennisl
Post
by dennisl » Dec 12th, ’17, 00:24
It just happened to me when creating a new folder called "Evernote" and I wasn't sure if it was the auto complete module kicking in, so I took a screenshot and thought I would post it... but I see you have responded that you know what the issue is.
Thanks very much Marko!
