Punctuation problems with FastKeys
vglzng
Post by vglzng » Nov 14th, ’16, 14:10
Bare with me here while i will try to explain my problem.
I'm dutch and the normal way to use punctuation (i will use " in my example) on my system is:
Press shift + " then hit spacebar. No problem so far, but the next character (lets say e) will get an ë. It looks like this: "ë
This is not an keyboard setting (i use dutch language with US international keyboard) and if FastKeys is closed is works properly.
Also if FastKeys is paused i still have this problem.
Am i doing something wrong? Is this expected behavior?
Post by Marko » Nov 16th, ’16, 08:06
Thanks, I was able to reproduce this. We will see what might be the issue and will try to solve it in the next release.
Guest
Post by Guest » Nov 16th, ’16, 08:09
Thanks Marko,
This was really bugging me, because i'm full in FastKeys. Really liking it!
gustms
Post by gustms » Nov 19th, ’16, 18:46
Great, I was having this problem for a time now, and never came to my head that it could be fastkeys, because it happened with it disabled as well.
But if I close FastKeys, problem is gone. Thanks a lot for finding this. Hope you guys can fix it! Thanks!
