Preserving clipboard
JDG
Post by JDG » Feb 4th, ’16, 18:27
Does FastKeys preserve the clipboard history when the PC is restarted?
Thanks
Post by Tom » Feb 4th, ’16, 23:03
This option is currently not available. Might be added in the future... ;)
Guest
Post by Guest » Apr 11th, ’16, 03:13
You can simply write the clipboard contents to a file -
then on startup - read that file in -
You can create a script that runs on boot-up - see the 'Menu' script options at the bottom of the dialog box.
Is really very easy -
Walker
