Show Text Expander suggestions as you type
JGM22
Post by JGM22 » Nov 27th, ’15, 19:57
I enabled the Show Text Expander suggestions as you type and it does not seem to work on my primary computer. I installed FK on a secondary computer and created 3 text expander's and it worked.
The only difference between the 2 computers is on my primary computer, the text expanders are in separate tabs whereas on the secondary computer I am using the single default tab.
Thoughts?
FYI - I also enabled auto completion using 2 characters for my configuration.
Thank you...JGM
Post by Marko » Nov 27th, ’15, 22:02
thanks for your tests. I can not reproduce the issue - on all our computers it works with one or more tabs. Could you check the settings?
JGM22
Post by JGM22 » Nov 27th, ’15, 23:29
Marko,
It appears my settings.ini was corrupted, I created a new one and everything is now working.
Thx...JGM
