When saving a string, a few people in the office get error code. The strange part is that this happens only to a few people, for the others works fine. We tried to reinstall and install again (a few times) but was not helping. Any suggestions?
Error code
kostenurka
Could you post the command that is causing the issue?
You can also send Settings.fdb file (or the one being used on computer where it does not work) to our mail address to see what might be wrong.
kostenurka
We tried a few different ones, all of them in text expander (pretty simple things - example ".pnz" and the substitute "Thank you for your time". And the error code says it is not a valid key name and some numbers. Will try to send the other details on your email. Thanks in advance.
