Nprotect Gameguard blocking FastKeys?
jogosdobb
Post by jogosdobb » Aug 30th, ’15, 13:36
Hello community
I've been using FastKeys to simulate mouse buttons as keys. MouseButton5 was my F2, MouseButton4 was my F4, MiddleMouseButton was my F7 and so on...
But, there was an update in the game and they added Nprotect Gameguard, sort of an hackshield, and all my shortcuts throught FastKeys stopped working
Is there any way to get around this and make it work in game?
Thank you for your time
Post by Marko » Aug 30th, ’15, 22:09
Some games treat this as cheating and do everything they can to prevent it. It will probably not work but you can try some other alternatives like (Type: Command)
SendPlay, {F2}
SetMouseDelay, 0, 50, Play
SendPlay, {F2}
Send {F2 down}{10}{F2 up}
SendPlay {F2 down}{F2 up}
Send {F2 down}
Sleep, 10
Send {F2 up}
More information:
http://www.autohotkey.com/docs/FAQ.htm#games
jogosdobb
Post by jogosdobb » Aug 31st, ’15, 22:27
Thanks a lot for you answer but as you said, it didn't work.
Should I use any of the Optional Attributes?
Post by Marko » Aug 31st, ’15, 23:33
no, optional attributes will not help. After reading some other forums, it looks like there is no hack for Nprotect Gameguard yet.
jogosdobb
Post by jogosdobb » Sep 1st, ’15, 09:37
Yeah I've also researched a lot. I was hoping I would find some solution here.
Thank you anyway
