Hi
I'm trying to run a command only in Windows 8.1 File Explorer. Only thing that gives any positive result is ahk_class CabinetWClass, which is always the ahk class according to Window Spy, but the command works only when I have windows search active. Any advice?
File Explorer window title?
lehmakommionu
ahk_class CabinetWClass is a correct window name for Windows Explorer. But I confirm it doesn't work reliably in Windows 8.1. I'll check if possible improvements can be made in the next version.
