Hello!
Right clicking the tabs toolbar (anywhere near Default or any other tab) is creating a new tab, and I can't open the menu to edit, rename or delete the tabs. Is it happening for anyone else?
Version 2.22a here.
Thank you!
Right click is creating a new tab
Strange, never happened to me. It looks like you are also selecting a first context menu item. Did you add any commands involving right click?
Could you try reloading FastKeys or restarting Windows?
Tried both reloading and restarting Windows. Nothing changed.
Right click works everywhere else in fastkeys and Windows, except for the tabs bar in any of the modules. I have no action set to right click. Gesture is set to right mouse button, but while holding Alt as well.
Tried disabling the Gesture module, setting it to the default setting (without pressing Alt) and nothing.
Your idea of it choosing the first option (New Tab) is correct, I think. I can see very briefly the popup before creating the new tab.
Any other suggestion of what I could try? Thanks a lot in advance.
