Hi Marko
In the Auto Complete section I want to use the wordlist: Common Business E-mail Phrases
That works fine, but sentences like "A quick note to tell you" don't show because the minimum word length to show suggestion is 4 and I want to leave it that way
How can I get it to work? Is there a settings in the prefences that I overlooked?
As you mentioned, you can change the Minimum word lenght to show suggestion (Preferences/Auto Complete) to 1 but this is not practical in all cases.
But I agree, the phrases begining with "I" or "A" do not make sense, it would be better for example to remove "A" from your phrase so it would respond to "quick"...
I should have updated the examples in this phrase file.
