Faraway
Post
by Faraway » Dec 19th, ’14, 20:54
hello,
In Fastkeys textexpander I'm trying to create some strings with description,but it seems one fails. If I try to create an á (r-alt + a) to use in a sentence in text expander it does nothing but é í ó are no problem. In any other program the á works.. What am I doing wrong?
/cheers
Far
Post
by Marko » Dec 19th, ’14, 22:35
Thanks, this is strange.
We will check what might cause this issue and correct it as soon as possible.
