Feature Request:Insert recorded macro context menu available in more places
mr9bitbyte
More specifically, having the insert recorded macro available inside an existing shortcut, or text expander item, or start menu, if its in "command" mode, the recorded macro would be pasted as is, if being inside a "send" mode, then the recorded macro would be inserted as a command item.
hank you for the suggestion. I’ll add it to the wish list.
