Windows Terminal Powershell 7
reconrad50
Post by reconrad50 » Nov 4th, ’25, 14:17
I did a search on the forum but didn't find anything related to my issue.. when i run windows terminal, it appears that it ignores anything that I attempt using Fastkeys or Autohotkeys for that matter. Is there a workaround or a setting that I need to change? TIA
Post by Marko » Nov 5th, ’25, 21:23
Please try running the Terminal as administrator and see if this helps.
