On clipboard manager copy button not work!
Formingus
Post by Formingus » Oct 10th, ’25, 17:19
On the clipboard manager, the copy button does not work! Click on the copy button; it will not copy even if I execute CTRL+C via keyboard. The only way to copy is via select > right mouse click > copy. Any idea why? BTW, there is no conflict on CTRL+C.
Post by Marko » Oct 14th, ’25, 15:06
I tried on our computers and it work as expected. What kind of the data are you copying?
Formingus
Post by Formingus » Oct 17th, ’25, 19:37
The data that you see on Clipboard Manager.
Now to clarify. When we copy it, it should go to the manager,
when we click on the copy icon on the manager, it should be copied to the clipboard, right ?
That does not happen, when i press copy icon on manager, text will not copy to clipboard
Formingus
Post by Formingus » Oct 17th, ’25, 19:42
Marko wrote: Oct 14th, ’25, 15:06 I tried on our computers and it work as expected. What kind of the data are you copying?
Obviously something is not right because even the hotkeyImage will not pull the request; sometimes it will show on the hotkey, sometimes not, but the copy button has never worked. I end any possible application to avoid hotkey conflict. I try different hotkeys, but the problem persists. Any suggestions?
Formingus
Post by Formingus » Oct 17th, ’25, 19:47
https://youtu.be/tIIiIFVzvPI
https://youtu.be/tIIiIFVzvPI For better explanation due language restriction
Post by Tom » Oct 18th, ’25, 20:21
First you need to select the text in the editor and then click the Copy button - this will copy the text to the clipboard entry. Click one of the number buttons to paste the selected clipboard item.
Formingus
Post by Formingus » Oct 19th, ’25, 15:23
Simply something is not right, i dont say that software has a bug but there is some conflict with it
