Letters or extended numbering for menu selections
robpenfold
Post by robpenfold » Sep 30th, ’25, 06:23
I use FastKeys at work (thanks to the portable option) and find it very useful
I have one text expansion for work URL's that displays a menu with 30 or so entries (see here https://imgur.com/a/xbdUdko for image)
The automatic numbering gives a number for the first 9 entries, but after that nothing
Would it be possible to have an option to use letters for selection as that would cover 26 of the entries
Even better would be numbering that continues beyond 9 (although would require some delay mechanism such that when you are selecting 26 say you don't end up with selection 2 instead etc)
(Perhaps this is an option somewhere already and I've missed the setting)
Thanks, Rob
Post by Marko » Sep 30th, ’25, 09:58
Numbers are provided as shortcuts and it only works for 1-9 keys. We can think if it would be possible to improve it in one the future releases.
robpenfold
Post by robpenfold » Oct 2nd, ’25, 21:45
Marko wrote: Sep 30th, ’25, 09:58 Numbers are provided as shortcuts and it only works for 1-9 keys. We can think if it would be possible to improve it in one the future releases.
Thanks - sounds good
