jolly
Post
by jolly » Apr 5th, ’25, 00:02
Is there any way to get the automatic update menu icons feature to work for entries that are not just a URL/APP? ie partial matches?
EX: I have a start menu entry
C:\scripts\OpenFind.exe https://chat.openai.com/chat "ChatGPT"
or
C:\scripts\OpenFind.exe %LOCALAPPDATA%\slack\slack.exe
It'd be great to have it download and use the correct icons for me.
(OpenFind is an ahk script that will find that open window, or launch the app. For webpages it launches it in a single app window)
Theres also a bug where it wont always correctly get the icon - for example
https://gemini.google.com
Post
by Marko » Apr 5th, ’25, 18:38
Thanks, we'll see if this could be improved in one of the future releases.
Until then you can manually set any menu icon.
jolly
Post
by jolly » May 21st, ’25, 21:07
also it overrides existing icons that I've manually added :/ @marko
Post
by Marko » May 26th, ’25, 16:29
FastKeys tries to retrieve the favicon from the webpage, but it seems the Gemini page icon is not located in the standard location. Manually added icons should not be overridden. Can you reproduce the issue step by step?
