Use mouse button & wheel to activate a command
Ennovy
Post by Ennovy » Mar 18th, ’14, 08:58
I am evaluating the portable version of FastKeys and I am impressed by all it's features.
I want to create a command to browse forward and backward in Firefox using the right mouse button in combination with the mouse wheel, but I don't know how to do this.
Thanks in advance for your support
Post by Marko » Mar 18th, ’14, 09:58
Currently there is only indirect way to do this. We will think about allowing complex shortcuts like this in the future.
For now you can make a Start Menu item, Type=Command, Options=AutoRun:
Command:
~RButton & WheelDown::
Send ^{Tab}
~RButton & WheelUp::
Send ^+{Tab}
Ennovy
Post by Ennovy » Mar 18th, ’14, 10:14
Thanks for the quick reply Marko!
The mouse combination works great to activate the command, but the command I need is : browse to previous or next page visited in my browser.
When I hold down the right mouse button I hear a sound. Can this be deactivated?
Post by Marko » Mar 18th, ’14, 12:37
sorry, try this:
Send {Browser_Back}
Send {Browser_Forward}
Right mouse button is by default also a mouse gesture key. To not hear the sound you can disable gestures module or untick the option Play sound for no match (under Preferences/Gestures).
Ennovy
Post by Ennovy » Mar 18th, ’14, 13:27
Thanks Marko
