Advanced shortcut
mokka
Post by mokka » Jan 23rd, ’14, 13:49
Hello, I have a question - I wonder if Fastkeys would help me with playing Call of Duty and some other games.
I see a lot of possibilities for advanced shortcuts but is there a way to have a keyboard shortcut of two regular keys pressed together, like if I simultaneously press D and F something happens?
Thanks and good luck with this GREAT application!
Post by Marko » Jan 25th, ’14, 18:44
You can do this indirectly. Replace msgbox with your code.
Type=Command
d & f::
msgbox Do Something
mokka
Post by mokka » Jan 31st, ’14, 13:30
Thanks, great solution!
