Clipboard shortcut
george_lobo
Post by george_lobo » Dec 10th, ’22, 03:51
hello help please
In the previous version of FastKey, you used the | key to activate the clipboard shortcut.
But now in this new version it no longer appears
How can I activate the clipboard with that key?
I can't find that key in the list
Jorge Aguero Lobo
Post by Marko » Dec 11th, ’22, 21:05
There is no need to open the Advanced shortcut window, just click on the shortcut control and press the key. On my computer the key is called Cedilla.
george_lobo
Post by george_lobo » Dec 13th, ’22, 04:05
Thanks Marko, that's how it worked
Jorge Aguero Lobo
