Some Autohotkey scripts are not running
Elermino
Post by Elermino » Nov 12th, ’21, 19:49
I usually implement autohotkey scripts in keyboard shortcuts by specifying that it is a command. Sometimes they do not work and error screens appear showing that some variables do not exist or the commands are not recognized, being that the same command works when I create an ahk document. Is there a solution for this problem?
Post by Marko » Nov 12th, ’21, 21:11
Could you post the example script which is not working?
Elermino
Post by Elermino » Nov 13th, ’21, 16:25
It is used to show a wave when the mouse is inactive for a certain time and when any of the mouse buttons are pressed
#NoEnv
CoordMode Mouse, Screen
Setup()
~LButton::ShowRipple(LeftClickRippleColor)
~RButton::ShowRipple(RightClickRippleColor)
~LControl Up::ShowRipple(MouseIdleRippleColor)
Setup()
    Global
    RippleWinSize := 200
    RippleStep := 10
    RippleMinSize := 10
    RippleMaxSize := RippleWinSize - 20
    RippleAlphaMax := 0x60
    RippleAlphaStep := RippleAlphaMax // ((RippleMaxSize - RippleMinSize) / RippleStep)
    RippleVisible := False
    LeftClickRippleColor := 0xff0000
    RightClickRippleColor := 0x0000ff
    MouseIdleRippleColor := 0x008000
    DllCall("LoadLibrary", Str, "gdiplus.dll")
    VarSetCapacity(buf, 16, 0)
    NumPut(1, buf)
    DllCall("gdiplus\GdiplusStartup", UIntP, pToken, UInt, &buf, UInt, 0)
    Gui Ripple: -Caption +LastFound +AlwaysOnTop +ToolWindow +Owner +E0x80000
    Gui Ripple: Show, NA, RippleWin
    hRippleWin := WinExist("RippleWin")
    hRippleDC := DllCall("GetDC", UInt, 0)
    VarSetCapacity(buf, 40, 0)
    NumPut(40, buf, 0)
    NumPut(RippleWinSize, buf, 4)
    NumPut(RippleWinSize, buf, 8)
    NumPut(1, buf, 12, "ushort")
    NumPut(32, buf, 14, "ushort")
    NumPut(0, buf, 16)
    hRippleBmp := DllCall("CreateDIBSection", UInt, hRippleDC, UInt, &buf, UInt, 0, UIntP, ppvBits, UInt, 0, UInt, 0)
    DllCall("ReleaseDC", UInt, 0, UInt, hRippleDC)
    hRippleDC := DllCall("CreateCompatibleDC", UInt, 0)
    DllCall("SelectObject", UInt, hRippleDC, UInt, hRippleBmp)
    DllCall("gdiplus\GdipCreateFromHDC", UInt, hRippleDC, UIntP, pRippleGraphics)
    DllCall("gdiplus\GdipSetSmoothingMode", UInt, pRippleGraphics, Int, 4)
    MouseGetPos _lastX, _lastY
    SetTimer MouseIdleTimer, 5000
    Return
MouseIdleTimer:
    MouseGetPos _x, _y
    if (_x == _lastX and _y == _lastY)
        ShowRipple(MouseIdleRippleColor, _interval:=20)
    else
        _lastX := _x, _lastY := _y
    Return
ShowRipple(_color, _interval:=10)
    Global
    if (RippleVisible)
    	Return
    RippleColor := _color
    RippleDiameter := RippleMinSize
    RippleAlpha := RippleAlphaMax
    RippleVisible := True
    MouseGetPos _pointerX, _pointerY
    SetTimer RippleTimer, % _interval
    Return
RippleTimer:
    DllCall("gdiplus\GdipGraphicsClear", UInt, pRippleGraphics, Int, 0)
    if ((RippleDiameter += RippleStep) < RippleMaxSize) {
        DllCall("gdiplus\GdipCreatePen1", Int, ((RippleAlpha -= RippleAlphaStep) << 24) | RippleColor, float, 3, Int, 2, UIntP, pRipplePen)
        DllCall("gdiplus\GdipDrawEllipse", UInt, pRippleGraphics, UInt, pRipplePen, float, 1, float, 1, float, RippleDiameter - 1, float, RippleDiameter - 1)
        DllCall("gdiplus\GdipDeletePen", UInt, pRipplePen)
    else {
        SetTimer RippleTimer, Off
    VarSetCapacity(buf, 8)
    NumPut(_pointerX - RippleDiameter // 2, buf, 0)
    NumPut(_pointerY - RippleDiameter // 2, buf, 4)
    DllCall("UpdateLayeredWindow", UInt, hRippleWin, UInt, 0, UInt, &buf, Int64p, (RippleDiameter + 5) | (RippleDiameter + 5) << 32, UInt, hRippleDC, Int64p, 0, UInt, 0, UIntP, 0x1FF0000, UInt, 2)
    Return
Post by Tom » Nov 15th, ’21, 21:07
Your script is dependent on a Gdip library which is not found. I suggest you run such advanced scripts using Type: Run.
Elermino
Post by Elermino » Nov 15th, ’21, 22:42
Tom wrote: Nov 15th, ’21, 21:07 Your script is dependent on a Gdip library which is not found. I suggest you run such advanced scripts using Type: Run.
Placing the code and selecting type run does nothing. I guess you mean creating a separate ahk file and putting its address, in that case it works
