FastKeys 5.0 Released
Post by Marko » Jan 24th, ’21, 18:39
New major version 5.0 release with many new powerful features and enhancements.
Please note that this is a separate version release and not a free upgrade. Existing users can continue using version 4 which will still be supported.
We do offer a 40% upgrade discount for registered users for a 3 month limited time period - click "Redeem Coupon Code" on a purchase page and enter your valid registration key. MORE INFORMATION
What's new in FastKeys 5.0:
January 24, 2021
Release notes:
- Enhanced and modernized Gui,
- Added Toolbars - always on top start menus with customizable settings,
- Added Open webpage macro,
- Added Run program macro,
- Added Open file macro,
- Added Open folder macro,
- Added Create mail macro (Professional Edition),
- Added Activate window macro,
- Added Selection Table macro (Professional Edition),
- Added Excel lookup macro (Professional Edition),
- Added Text file lookup macro (Professional Edition),
- Added Excel Data range macro (Professional Edition),
- Added Calculation macro (Professional Edition),
- Enhanced Manual Text Input options (Default text, Input format, Multi line)
- Added No output option to several macros,
- Added Output format options to several macros,
- Enhanced font dialogs with Unlimited color selections,
- Enhanced resizable Quick find window,
- Simplified Run type - now covers Run, Open and Script type commands,
- Added Gui color themes,
- Added Customizable Gui icon bar,
- Added Display number of items in module,
- Added Option to include spaces in Auto Complete search,
- Added Option for defining Selection form popup width,
- Added Auto import from previous FastKeys versions,
- Updated documentation,
- Updated translations,
- Abundance of other improvements and bug fixes.
Comments, suggestions or bug reports are highly appreciated. :D Thanks!
Thanks and stay safe!
Download FastKeys HERE.
gustms
Post by gustms » Jan 24th, ’21, 18:40
Awesome! Thank you for the frequent updates!
weberwa2
Post by weberwa2 » Jan 27th, ’21, 14:20
The Symantec protection here yesterday identified the new install files as «could contain a virus» (Symantec is configured here that every new like a virus. In the meantime I sent the two installer files (the standard file and the portable file) to Symantec' «false positive llsit», and in today I got the message from Symantec that both files are now identified as *not malicious*.
So hopefully we all with Symantec protection will be able to install soon! :D
Kind regards –
Walter
Post by Marko » Jan 28th, ’21, 10:20
Thanks Walter for your support, very much appreciated. :)
weberwa2 wrote: Jan 27th, ’21, 14:20In the meantime I sent the two installer files (the standard file and the portable file) to Symantec' «false positive llsit», and in today I got the message from Symantec that both files are now identified as *not malicious*.
FastKeys is clean and safe software. Some web security or antivirus software may occasionally wrongly suspect FastKeys as Spyware because it processes keyboard input. Such reports are false and FastKeys is absolutely safe to use. In such cases please to manually unblock FastKeys from the quarantine manually until the issue is resolved.
Post by Marko » Jan 28th, ’21, 10:24
Fixed "Run FastKeys on startup" not working properly in certain cases.
If you experience this issue just download and install again.
