Hi. I really like this feature but sometimes it's a bit annoying.
Can we have the option to add exclusions to this feature like ID, IP, MR, MS etc please?
Customize Correct Double Capitals
I see what you mean, we will take a look and try to optimize this behavior.
The problem is that the list of exclusions could be very long. Alternatively we could disable the correction for all letters followed by a space, comma etc. but this would result in many missed valid cases (My, It, He etc.).
The correction is only triggered if the second letter is typed very quickly after the first one. If you are aware of this you could simply remember to type the mentioned acronyms a little slower which would solve the issue.
I understand what you mean and apologize for the misunderstanding.
I'm asking if it's possible for you to add user-defined exclusions for this feature.
This could simply be a textbox where I can enter a comma-separated list of words I want excluded from this feature.
Example screenshot
Example screenshot
