I'd appreciate your help regarding running applications under %A_Appdata% from Fastkeys start menu.
The two commands below works properly when running from a regular ahk script:
Run, "C:\Users\%username%\AppData\Local\Programs\Moo.do\Moo.do.exe"Code: Select all
Run, "%A_Appdata%\Local\Programs\Moo.do\Moo.do.exe"What would be a syntax that would work with Fastkeys?
PS.: I do not intend to use the full/absolute path with username since the Fastkeys menu should work from other user accounts too.
Thank you,
Carlos
