How to trim extra space when selecting text?
Post by Tom » Jul 24th, ’19, 21:00
I'll try over the weekend. ;)
revavi
Post by revavi » Jul 24th, ’19, 22:54
All right! I'll be waiting. Thank you! :D
Post by Tom » Jul 27th, ’19, 10:34
How about his? Notepad Format/WordWrap must be set to off.
filename:="words.txt"
delimiter:=";"
Send, ^c
Sleep, 200
word=%clipboard%
FileRead, OUT, %filename%
found:=0
Loop, Parse, OUT, `n, `r
	if A_LoopField contains %word%%delimiter%
        StringSplit, COL, A_LoopField, %delimiter%
        if not COL2
            Run notepad %filename%
            WinWaitActive, ahk_class Notepad
            Send, ^g%A_Index%{Enter}^+{Right}
        else
            Msgbox, 64,, % COL1 "`n`n" COL2
        found:=1
        break
if not found
	FileAppend, `n%word%%delimiter%, %filename%, UTF-8
	Send, ^{End}
revavi
Post by revavi » Aug 4th, ’19, 07:43
Hi Tom,
I was on vacation. Thank you very much for the code. It works flawlessly!
