Is there a way to just do autocomplete on keypress
Archivist
Post by Archivist » Aug 9th, ’18, 15:42
Is there a way to turn off autocomplete EXCEPT when I do the keyboard shortcut. That is, if I have a shortcut "md" (month day) instead of having it constantly scan whatever I'm typing for "md", can you have it just do an autocomplete if I use my mapped shortcut (e.g.., ctrl-space). If that doesn't work I probably need to make my shortcuts more different (e.g., mmd)
Post by Marko » Aug 9th, ’18, 20:55
You can disable Auto Complete by disabling the wordlists individually or by disabling the whole module in Preferences/Module activation.
Archivist
Post by Archivist » Aug 13th, ’18, 16:06
Worked perfectly. Now I use ctrl-space to see the autocompletes. Great tool best on market!
