Meta-searching with 1 keyword
MIA_fastkeys
Post by MIA_fastkeys » Jul 30th, ’18, 00:16
Hi all,
Meta-searching is when you type "shop <<keyword>>" and that opens up multiple browser sites searching Amazon, Walmart, Google express, etc.
It is an ULTIMATE productivity method that very few people use. There just has to be a way to do this in Fastkeys.
I thought of starting with the following entry:
https://i.imgur.com/rBqxvyN.png
What I want to do is press a keystroke (example: ALT+G) and then the window comes up: https://i.imgur.com/va6mV1T.png
I type in "g ___search text____" to search google, google images etc.
typing in "shop ____search text___" would open a browser & search walmart, google express amazon
typing in "tools ____search text____" would open a browser & search home depot, walmart, lowes, amazon
I have all of the search entries already:
For example, home depot: http://www.homedepot.com/s/{query}?NCNI-5
Can anyone please help or recommend a way of doing this?
Post by Marko » Jul 30th, ’18, 19:52
Nice challenge. Please add search entries for other sites and post the complete script here :D
Type: Command
InputBox, Input, Meta search, Prefixes: g`, shop`, tools, , 300, 120
DivPos:=InStr(Input, " ")
Prefix:=SubStr(Input, 1, DivPos-1)
SearchText:=SubStr(Input, DivPos+1)
StringReplace, SearchText, SearchText, %A_Space%, `%20, All
StringReplace, SearchText, SearchText, #, `%23, All
SearchText:=Trim(SearchText)
if (Prefix="g")
	Run, "www.google.com/search?hl=en&q=%SearchText%"
	Run, "www.google.com/search?site=imghp&tbm=isch&q=%SearchText%"
	Run, "www.google.com/maps/search/%SearchText%"
else if (Prefix="shop")
	Run, "www.amazon.com/s/ref=nb_sb_noss?url=search-alias`%3Daps&field-keywords=%SearchText%"
	Run, "www.ebay.com/sch/%SearchText%"
else if (Prefix="tools")
	Run, "www.homedepot.com/s/%SearchText%?NCNI-5"
MIA_fastkeys
Post by MIA_fastkeys » Jan 7th, ’19, 03:08
Marko,
sorry I didn't see this in time. I turned notifications on. I am getting an error with this script when implemented. It even crashed a few times!
;DON'T FOREGET TO REPLACE %SearchText% WITH %SearchText%
if (Prefix="g")
	Run, "https://smile.amazon.com/s/ref=nb_sb_noss_2?url=search-alias%3Daps&field-keywords=%SearchText%"
	Run, "http://smile.amazon.com/s/ref=nb_sb_noss?url=me%3DA2L77EE7U53NWQ&field-keywords=%SearchText%&x=0&y=0"
	Run, "http://camelcamelcamel.com/search?sq=%SearchText%"
	Run, "https://www.costco.com/CatalogSearch?dept=All&keyword=%SearchText%"
	Run, "http://www.homedepot.com/s/%SearchText%?NCNI-5"
	Run, "https://www.inoreader.com/search/%SearchText%/public"
	Run, "https://jet.com/search?term=%SearchText%"
	Run, "http://www.lowes.com/Search=%SearchText%?storeId=10151&langId=-1&catalogId=10051&N=0&newSearch=true&Ntt=test#!"
	Run, "http://www.monoprice.com/Search?keyword=%SearchText%"
	Run, "http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=%SearchText%"
	Run, "http://slickdeals.net/newsearch.php?q=%SearchText%&searcharea=deals&searchin=first"
	Run, "https://www.walmart.com/search/?cat_id=0&facet=retailer%3AWalmart.com&query=%SearchText%&vertical_whitelist=home%2C#searchProductResult"
	Run, "http://www.target.com/s?searchTerm=%SearchText%"
	Run, "https://www.costcobusinessdelivery.com/CatalogSearch?storeId=11301&catalogId=11701&langId=-1&keyword=%SearchText%"
	Run, https://www.bestbuy.com/site/searchpage.jsp?st=%SearchText%&_dyncharset=UTF-8&id=pcat17071&type=page&sc=Global&cp=1&nrp=&sp=&qp=&list=n&af=true&iht=y&usc=All+Categories&ks=960&keys=keys"
	Run, "http://www.acehardware.com/search/index.jsp?kwCatId=&kw=%SearchText%&origkw=%SearchText%&f=Taxonomy/ACE/19541496&sr=1"
	Run, "https://www.bhphotovideo.com/c/search?Ntt=%SearchText%&N=0&InitialSearch=yes&sts=ma&Top+Nav-Search="
	Run, "https://www.adorama.com/l/?searchinfo=%SearchText%"
	Run, "https://www.bedbathandbeyond.com/store/s/%SearchText%?ta=typeahead"
	Run, "https://www.staples.com/%SearchText%/directory_%SearchText%?"
	Run, "https://www.rakuten.com/search/%SearchText%/"
	Run, "https://express.google.com/s?q=%SearchText%"
	Run, "https://www.google.com/express/search?m=9090995&q=%SearchText%&oq=%SearchText%&g_sl=localmall.3..47.875419.875897.0.875968.4.4.0.0.0.0.108.292.3j1.4.0...0.0...1ac.1.Jy7_yZjVbcU"
	Run, "https://www.inoreader.com/search/%SearchText%"
Picture:
Is this a bug?
Post by Tom » Jan 13th, ’19, 10:30
Try this. There were syntax errors in your script - I escaped % characters, corrected "elseif" to "else if" and added control if cancel is pressed or the entered string is empty.
InputBox, Input, Meta search, Prefixes: g`, shop`, Tools`, costco`, Music`, Movie etc.,, 320, 130
if errorlevel
if not prefix
if (Prefix="g")
	Run, "https://smile.amazon.com/s/ref=nb_sb_noss_2?url=search-alias`%3Daps&field-keywords=%SearchText%"
	Run, "http://smile.amazon.com/s/ref=nb_sb_noss?url=me`%3DA2L77EE7U53NWQ&field-keywords=%SearchText%&x=0&y=0"
	Run, "https://www.walmart.com/search/?cat_id=0&facet=retailer`%3AWalmart.com&query=%SearchText%&vertical_whitelist=home`%2C#searchProductResult"
else if (Prefix="Tools")
	Run, "https://www.harborfreight.com/catalogsearch/result/index/?dir=asc&limit=60&order=EAScore`%2Cf`%2CEAFeatured+Weight`%2Cf`%2CSale+Rank`%2Cf&q=%SearchText%"
else if (Prefix="costco")
	Run, "https://costco97.com/?s=%SearchText%"
	Run, "http://www.adamcos.com/Costco/search.php %SearchText%"
	Run, "https://www.pricecase.com/search/all/%SearchText%"
	Run, "https://www.google.com/search?safe=off&biw=2004&bih=1052&tbm=isch&sa=1&ei=xXlfW6iMB9DS_wS8_onIBg&q=costco+%SearchText%&oq=costco+%SearchText%&gs_l=img.3...3682.5287.0.5500.8.8.0.0.0.0.132.669.6j2.8.0....0...1c.1.64.img..0.3.317...0j0i67k1.0.iGs0UiG5988"
else if (Prefix="Music")
else if (Prefix="Movie")
	Run, "http://www.imdb.com/find?s=all&q=%SearchText%"
else if (Prefix="Book")
	Run, "https://sfpl.bibliocommons.com/search?utf8=?&t=smart&search_category=keyword&q=%SearchText%&commit=Search"
	Run, "https://catalog.plsinfo.org/search/X?SEARCH=%SearchText%&searchscope=1&SORT=D"
else if (Prefix="PCApp")
	Run, "https://www.google.com/search?q=site:www.nsaneforums.com+%SearchText%&ie=UTF-8"
	Run, "https://cse.google.com/cse?cx=partner-pub-0492687750134555`%3A0046060402&ie=UTF-8&q=%SearchText%#gsc.tab=0&gsc.q=%SearchText%&gsc.page=1"
else if (Prefix="MA")
	Run, "https://macbb.org/search/%SearchText%"
	Run, "https://www.macserialjunkie.com/forum/search.php/%SearchText%"
else if (Prefix="Amazon")
	Run, "http://fakespot.com/analyze?utf8=`%E2`%9C`%93&url=%SearchText%"
	Run, "http://reviewmeta.com/amazon/%SearchText%"
MIA_fastkeys
Post by MIA_fastkeys » Jan 14th, ’19, 02:29
yay! thank you so, so, sooooo much Tom. You don't know how much this means to me! There's really no good solution for meta searching for windows. Mac has Alfred which handles it with extreme ease if you buy the powerpack, but windows users are left out in the cold. Strange for such a simple function :(
