Fastkeys error
I'm running Fastkeys version 4.07a and have been getting a "webpage script error" pop up at random times. System is Windows 10 Pro 64 bit. The error doesn't kill the fastkeys app, just pops up and if I hit "no" and don't run the debugger everything appears normal. Just for troubleshooting purposes though I chose "yes" and have it actually run the debugger. Screenshots attached.
Can you reproduce this? Could it be caused by some of your commands/scripts? You can send me your settings.fdb file for a check...
It happens randomly as far as I can tell.
I haven't been able to pinpoint a particular event (app, mouse or key sequence) that causes it. It doesn't happen very frequently maybe once every couple of weeks.
I can look through my settings file. Should I look in particular for items that may involve a parenthesis? As shown in the error?
After checking again, it's clear that the issue is caused by in-line calculator routine which is trying to evaluate a non-valid expression "(vas". Do you occasionally type something similar?
