March 24, 2018
New FastKeys update with some exciting new features:
- Quick Find - press Alt-Space shortcut to open a new search dialog which provides another way for easy access to all FastKeys commands. Type some keywords to search or press up, down, left and right keys to select commands and modules. You can also easily access latest executed commands. Quick find shortcut can be changed in Preferences/Shortcuts. In Preferences you can also select whether FastKeys should automatically search the currenty typed word.
- Manual Auto Complete - set a shortcut (Preferences/Auto Complete) to manually open auto complete suggestion window at any time. If you prefer, you may set "Minimum word length to show suggestion" option to 0 - this way automatic suggestions will be disabled, allowing full manual control.
Please let us know how you like the new features or if you have any comments.
Release notes:
- Quick find - quickly search for any FastKeys command and execute it,
- Manual Auto-Complete shortcut,
- Escape key behavior in popups improved,
- Improved DPI awareness,
- Various small improvements and bug fixes.
Download FastKeys HERE!
