FastKeys 3.13 Released
Post by Marko » Sep 24th, ’16, 16:29
What's new in FastKeys 3.13:
September 24, 2016
New release with new handy features:
- you can now select "..." button to assign a custom icon to start menu items. Select Auto or Custom icon options and then select an icon file from disk.
- random text generation syntax is now supported which allows you to randomize your text output. For example, "{Hello|Hi} world!" will send "Hello world" or "Hi world" alternatives. There are many possibilities. Nested syntax is also supported - see provided example. An the best of all, you can combine it with the power of existing FastKeys macros. :D This feature can be disabled in Preferences/Text Expander.
- there have been some reports of right-click issues when primary and secondary mouse buttons were switched - the behavior is now optimized.
- Spanish translation is available - thanks Salva!
Release notes:
- Assign custom icons to menu items,
- Random text generation syntax support (Spintax),
- Optimized mouse gestures for left hand use,
- Spanish language translation added,
- Language translation updates,
Download FastKeys HERE!
gustms
Post by gustms » Sep 25th, ’16, 22:51
Thank you for the update, Marko!
Pro
Post by Pro » Oct 3rd, ’16, 20:27
Release notes:
Amazing Support !!
Thank you very much :)
Danke! :D
=Jagz=
Post by =Jagz= » Oct 16th, ’16, 20:21
Marko,
Thanks for adding the ability to customize menu icons! Very helpful for quickly finding specific menu items.
I'm very impressed with your responsiveness to the user community and how much this utility has increased my productivity.
:D :D
