I have my History size set to 20, but after 4 items History item 1. is overwritten.
I've tried reinstalling FastKeys, running sfc and chkdsk.
Any ideas what I should do?
Clipboard Manager History Limited
Tested on my computers and it works as expected. Try disabling Allow Duplicates option under Preferences/Clipboard Manager.
I created another User and installed FastKeys in that account and everything works as expected. I'm trying to troubleshoot whatever setting is causing a problem in my default User Account.
lehmakommionu
exactly the same problem here. deactivated all the modules to make sure it's not interfering with any of the scripts i have.
