Issues with Webroot SecureAnywhere
David Buchan
Post by David Buchan » Feb 18th, ’16, 23:50
Having issues with Webroot blocking the command functions within FastKeys 3.07. Exceptions have been created but are not working suggesting some component is still being blocked. When Webroot is turned off Fastkeys works fine. Are there any files installed outside of "C:\Program Files (x86)\FastKeys" that we may have missed?
Thanks, David
Post by Marko » Feb 19th, ’16, 07:17
Some web security or antivirus software might block FastKeys and similar key logger software to prevent from capturing important information. One example is Webroot - try disabling "Web Threat Shield"​ option and see if it works.
