Is there a way to use fastkeys to have dynamic text for text snippets?
For example, the text snippet would say:
Dear Mr. XXX,
thank you for contacting me. The price is YYY. Let's meet next ZZZ.
So when I activate this snippet, the cursor will type out "Dear Mr.", and let me insert "Joe" manually, then continue expanding "thank you for contacting me. The price is", then letting me enter whatever I want, etc.
Any help greatly appreciated!
insert text dynamically
yes, this is possible, using a short code. Actually I can think of automating this via dynamic variables in the next version release of FastKeys. Thanks for an idea!
For the time being try this:
Type=Command
Command:
What do you think? Please let me know if you need more information.
Type=Command
Command:
gui, add, text,, Customer
gui, add, edit, xp+80 yp vCustomer
gui, add, text, xm, Price
gui, add, edit, xp+80 yp vPrice
gui, add, text, xm, Day
gui, add, edit, xp+80 yp vDay
gui, add, button, xm w75 h23 default, OK
gui, show
ButtonOK:
gui, submit
gui, destroy
Send, Dear Mr. %Customer%,`n`nthank you for contacting me. The price is %Price%. Let's meet next %Day%.
returnCommand slightly updated.
