Auto import from previous FastKeys versions
rjbull
Post by rjbull » Jul 26th, ’25, 21:43
I just upgraded from 5.17 to 6. I'm using the portable version, installed in a different directory from 5.17. The What's New page includes the line "Auto import from previous FastKeys versions".
Please, how do I do that? I can't immediately see anything in Settings. I could obviously copy from 5.17 to 6, but wasn't sure if you'd changed file formats.
Post by Marko » Jul 27th, ’25, 05:38
There is no change in file formats. Just use File/Open and select your settings file.
rjbull
Post by rjbull » Jul 31st, ’25, 21:32
Thanks. I was looking for an Import item under Preferences, didn't think to look at File Open :oops:
I was at first confused by settings.ini, until I realised it needed settings.fdb.
It didn't pick up all settings, though. Quick-add Shortcut, Text Expander font size, and Auto Complete Minimum word length to show suggestion were all things I noticed hadn't been re-set. Oh, well.
