Hello!
While I was looking for a mouse gesture alternative to StrokeIt, I came across Fastkeys and was really amazed at what it can do.
But there is a compatibility issue with Microsoft's PowerToys and FancyZones (which I can't live without). FancyZones allows you to drag a window with the primary mouse key and activate the FancyZones with a single right click while still holding the left button down and then dragging the window into a zone. This works well with StrokeIt, but Fastkeys handles it differently.
I tried playing with the settings, but nothing worked. So I would like to ask you to take a look at FancyZones and see if you can make it work with Fastkeys.
Edit: I forgot to mention that I changed the gesture activation key to RBUTTON only. It's working fine if the activation key is ^RBUTTON, but thats not what I want.
Thanks in advance
Martin
Feature Request: Harmonize with FancyZones from PowerToys
bitsper2nd
Have you tried adding native ~ to the RButton shortcut for the Gestures?
