Priority of shortcuts
roze
Post by roze » Jan 28th, ’25, 08:46
FastKeys is a great tool that has a lot of customizability. However, I have run into the problem when defining/using custom shortcuts .
For example, even Windows has a large set of its own shortcuts. Alternatively, other applications I use have their own shortcuts. It often happens that I want to use a shortcut in FastKeys, which conflicts with another application.
I would like to ask here if anyone has solved a similar problem?
Is there any way to assign FastKeys shortcuts a priority of use, before another application uses the same shortcut?
Post by Marko » Jan 30th, ’25, 11:39
FastKeys normally overrides other shortcuts. If you find later on other program has a useful function assigned to the same shortcut, simply change it or remove it
