Feature request
mr9bitbyte
Post by mr9bitbyte » Nov 10th, ’24, 07:07
Two things,
there is an option to record a macro with intervals, itd be nice to set a predefined interval like instead if it being exact time interval, just being able to specify a maximum interval like 250ms, or 50 ms, sometimes no intervals is too fast, but normal timing is too slow so being able to specify an interval that the macro instructions will be timed with would be great.
Also to have the option to edit a recorded macro and save it and keel using it as a recorded macro without having to save it to a shortcut, or menu or anything, just edit the macro you just saved.
Thanks for the hard work like always
Post by Tom » Nov 10th, ’24, 22:00
Thanks, we will consider this. But why not saving the recording to a dummy shortcut and edit it there?
mr9bitbyte
Post by mr9bitbyte » Nov 12th, ’24, 18:10
This is what I do already, I create a temporary menu for the recorded macro named as temp.
