I have two monitors connected to my PC. I use the left monitor as the main monitor.
In the FastKeys configuration I have set "Show menu on" Right edge in Menu1 in Start Menu.
Until now the menu appeared on the right edge of the left monitor - this suited me fine.
I don't know what caused it, but suddenly the menu started appearing on the right edge of the right monitor.
Is there any way I can limit the menu to displaying only the left monitor?
Show menu on and two monitors
If right edge is selected then the menu will always appear on the right edge of the most right monitor. You need to restart FastKeys after changing the monitor setup.
Yes, that explanation sounds logical, but the reality is sometimes different
https://drive.google.com/file/d/1-HppVh ... drive_link
https://drive.google.com/file/d/1-FMNNP ... drive_link
https://drive.google.com/file/d/1-Ep2V1 ... drive_link
What happens if you position the Task Bar to the bottom of the screen?
The menu display on the left monitor documented by the photos above does not always apply.
I don't know what might be affecting it.
Now I have the menu display set to the right edge, and the menu appears on the right side of the right monitor.
When I change the Settings to display the menu on the bottom edge,
it actually appears on the bottom, but only on the right monitor.
But when I set the display at the top edge, the menu appears on the left monitor.
