Troubleshooting Common Issues with FastKeys Automation - Emmanuel Katto Uganda
emmanuelkatto
Post by emmanuelkatto » Sep 30th, ’24, 06:46
Hi All,
My name is Emmanuel Katto. I’ve been using FastKeys for a bit now, and while it has greatly improved my efficiency, I’ve run into a few challenges that I could use some help with. Here are my questions:
I’ve noticed there’s sometimes a noticeable delay when I trigger shortcuts. Has anyone else experienced this? What steps can I take to troubleshoot or minimize this lag?
I’m using FastKeys on a system with several other automation tools. Are there known compatibility issues that I should be aware of? How have you managed potential conflicts between different programs?
I’m trying to utilize dynamic text expansion, but I’m not seeing the expected results. Can anyone share their experiences or best practices for setting up this feature correctly?
Your insights would be greatly appreciated!
Thanks in advance for your assistance.
Best,
Emmanuel Katto
Post by Marko » Oct 1st, ’24, 18:42
Hi Emmanuel and welcome to FastKeys forum.
There can certainly be a conflict between multiple automation tools. Have you tried the provided examples in the software?
What do you mean dynamic text expansion? I would invite you to check many available tutorial videos first. I suggest you start here:
Master FastKeys in Minutes: A Beginner's Guide for First-Time Users!
Check others too:
https://www.fastkeysautomation.com/videos.html
