Create a shortcut to move files to folder?
az329392
Post by az329392 » Sep 21st, ’24, 11:06
Is there a way to create a shortcut to move the select file or files to a specific folder? I'm trying to organize my files more quickly.
Post by Marko » Sep 21st, ’24, 13:52
Create a shortcut, Type: Command.
Set the destination folder in the first line, for example
DestDir:="D:\MyFolder"
DestDir := ""   ;set the destination folder here
Send, ^c
Sleep 100
Loop, Parse, clipboard, `n, `r
    FileMove, %A_LoopField%, %DestDir%
clipboard :=
Replace FileMove command with FileCopy if you want to copy.
az329392
Post by az329392 » Sep 23rd, ’24, 18:23
Awesome, thanks
