Program notion to make a comment, not sent complete
tonyrm06
Post by tonyrm06 » Aug 16th, ’24, 12:33
Good morning and thanks for your help in advance!
I am using notion in the company and when the comment is made the first part of the message is sent and not the rest, as it sees that it is an enter and send in planner does not happen to me.
Example:
The target volumes with the specific criteria:
%SELECT_Brand% %SELECT_Country% %SELECT_Circuit% %SELECT_Optin% %SELECT_Buyers% %SELECT_Gender% %SELECT_Engaged% %SELECT_beauty% -->
Confirmation of the segmentation count?
This is the message that I then customize but when I finish customizing it only this is sent
the rest is not sent I have done a test and this way it is sent fine.
The target volumes with the specific criteria:%SELECT_Brand% %SELECT_Country% %SELECT_Circuit% %SELECT_Optin% %SELECT_Buyers% %SELECT_Gender% %SELECT_Engaged% %SELECT_beauty% -->Confirmation of the segmentation count?
But the message is no longer read correctly so I want it with spaces.
I have tried with the spaces in the program to see if they are different and it does exactly the same, is there a way to send the message like the example?
Thanks again!
Post by Marko » Aug 18th, ’24, 21:11
It’s difficult to say. Can you please contact our support mail?
