[SOLVED] PROBLEMA CON EXPANDIR TEXTO
edwardmaya
Post by edwardmaya » Aug 6th, ’24, 21:45
EL MODULO EXPANDIR TEXTO, NO ME PERMITE USARLO EN NINGUN APLICATIVO, NI NAVEGADOR
EN EL UNICO PROGRAMA EN EL QUE CORRE ES EN WORD, A QUE SE DEBERIA EL PROBLEMA?
YA INTENTÉ VER CUAL SERIA EL PROBLEMA, PERO NO PUEDO IDENTIFICARLO
AYUDA :(
Post by Marko » Aug 6th, ’24, 21:49
Check your settings in the security software you are using (anti virus, keyboard protection etc.).
edwardmaya
Post by edwardmaya » Aug 6th, ’24, 21:52
Windows 11 y el antivirus es el NOD32
edwardmaya
Post by edwardmaya » Aug 6th, ’24, 22:12
Marko wrote: Aug 6th, ’24, 21:49 Check your settings in the security software you are using (anti virus, keyboard protection etc.).
Encontré la proteccion en navegación y se corrigió el problema. Gracias :)
