Hello!
I've been using autocomplete with a large dictionary of the most common english words over 5 letters; and it works great. However, I would like to turn it off in certain places and I'd like to turn it off without affecting Text Expander. How do I
1. Turn off AutoComplete in chrome URL bars and not text boxes? The window information gives me the name of the title "Vivaldi" and I can add it here--well nevermind, I can't seem to paste images into this form--I can add it to "Not Active In" but that prevents it from being active in textboxes on vivaldi. Is there a way to turn it off using the URL or popup name (like
2. If that's not possible I would still like to use text expander on Vivaldi. The text expander option of "Display suggestions as you type (Auto Complete settings)" is checked but the "Not Active In" under AutoComplete seems to override the TextExpander settings; feel like they should / I would like the AutoComplete and TextExpander settings to be different if possible?
Autocomplete Switchoff/on
1. Auto Complete can only distinguish between whole windows and not between URLs.
2. When "Display suggestions as you type" option is enabled, Text Expander string suggestions will appear according to Auto Complete settings. Regular Text Expander functionality will still work as usual, you just need to type the whole string.
