nsyrax
Post
by nsyrax » Mar 25th, ’24, 15:24
Is it not possible to use the Spintax random text option when using Rich Text? I have the following in a phrase:
{if you have any questions|if I can be of any assistance}
But it outputs that entire string when I output, even with the random option enabled.
Post
by Tom » Mar 25th, ’24, 18:58
You can use Non formatted text and then "insert another item" macro which contains rich text part.
