Hi all,
I am new to Fastkeys, I have been trying out a number of different text expander apps and think FK is the one I will purchase.
However, I am struggling to solve a very basic problem - how to have one text if a checkbox is selected, and a different phrase if left blank.
I can't figure out how to do it in FK.
How would I go about doing this please?
Thanks in advance.
Output if not checked
Negative selection value is currently not supported in a direct way, we will implement this in one of the next releases.
In the meantime you could use a Condition (If-Else) macro to achieve the same result. Alternatively you could also use Insert Command Code macro.
