Problem with shortcuts
mr9bitbyte
Post by mr9bitbyte » Jun 15th, ’23, 20:04
I have the following shortcut, but its not working. Please see image below, any ideas?
Post by Marko » Jun 15th, ’23, 20:27
What's not working? What would you like to do?
mr9bitbyte
Post by mr9bitbyte » Jun 15th, ’23, 22:19
the command is not excecuting, like the shortcut is not working. when I press Ctrl+Shift+D nothing happens. All the command is doing is a Ctrl+C and Ctrl+V, thats why is called duplicate.
Post by Marko » Jun 16th, ’23, 17:36
I think the shortcut is working. Try this code
Send ^c
Sleep 50
Send {Right}
Send ^v
