Insert another Item woes
Marty123
Post by Marty123 » May 25th, ’23, 11:06
When I create a message box under 'send' mode, I usually chose 'ok' / 'cancel' as choice of buttons for users to either click ok for fulfilling the condition to run the script, or click 'cancel' to abort. I find that when I, say, wanna insert the text expander script 'RunThis' under the 3 dots (insert another item) for example, the first 1 or 2 commands in "RunThis" will always be missing if "runthis" is used in this manner (i.e using message box's "ok/cancel" conditional environment). When i run 'runthis' natively, (meaning typing out manually to trigger it) all the commands are ran, and no missing commands. Do you encounter this?
Marty
Post by Tom » May 27th, ’23, 10:20
Hi Marty, I tried but cannot reproduce this. I would need to see the exact settings, please contact us on our mail support.
Marty123
Post by Marty123 » Jun 4th, ’23, 12:10
Hi Tom, I do not know how to break down the steps and email you. But it's ok, so long as i have a workaround, it's fine.
