Questions about the text extension function
leo8799
Post by leo8799 » May 17th, ’23, 15:59
Does the text expansion function of the software paste text directly into the text box, or does it simulate manual input into the text box?
I used this software when entering text into the text box, but it seems to be recognized as copy-and-paste text.
I use translation software to translate my ideas, there may be inaccurate description, look forward to your reply :D
Post by Tom » May 17th, ’23, 17:37
It can do both. By default it simulates key presses. If "Use clipboard" option is enabled, it will use a Paste method.
mr9bitbyte
Post by mr9bitbyte » May 27th, ’23, 18:48
Tom wrote: May 17th, ’23, 17:37 It can do both. By default it simulates key presses. If "Use clipboard" option is enabled, it will use a Paste method.
If use clipboard selection is selected, it would be extremely useful if there was an option to restore previous clipboard entry, I iamgine right now there is not and the clipboard will be replaced.
Post by Tom » May 27th, ’23, 19:18
The clipboard is preserved.
