I keep getting double letters when I type
For instance when I type MS Teams it backs up and replaces it with MSSTeams and I have to keep deleting the extra S.
I have noticed it typing double upper case letters with other words as well
This happens even when I am typing another letter it will duplicate the last capital letter I have typed regardless.
The OS is Windows 8.1 on a VM
Double Upper Case
Do you use a specific Auto Complete wordlist? Try to disable it to see if it helps.
Also, try to disable Auto-correct options in Preferences/Functions - Correct sentence capitals and Correct double capitals. Any difference?
